Force calibration update
MatixSRT03
Post by MatixSRT03 »
hi , im new to the forums and have a question . i bought a used pcm for my 2003 dodge srt4 and when trying to load the 93 tune it says that it cant back up because there is a predator tune installed. the seller of the pcm swears there was no tune on it but the way it runs it seems that there is. i know from searching that diablosport can do a force calibration update to return the pcm to factory specs correct? i bought my predator used and do not have the data cable with it, is this needed to perform the calibration? also i built the srt4 i have from a regular neon and dont have the srt4 vin for 2003. i have one from an 05 i think. the whole reason i switched pcm's was to correct a lean idle fuel trim and this pcm i got works perfect but i want the tune out of it so i can load mine and adjust parameters.I plan to call monday morning but want to know if i need the above items. thanks in advance
Re: Force calibration update
give us a call with the tool powered up in the car.
Not sure how the VIN may affect things, but we can get a stock file back in there.
MatixSRT03
i did call this morning and you guys over there were very helpful! its good to know i can count on diablosport to take care of issues like this with such ease!
Return to “General Questions”
