"Error Code=0x00000386"
pacificcoast
Post by pacificcoast »
After updating "Error Code=0x00000386"and is displayed and i-1000 programmer became impossible.
It has not improved, although the 1r03x file was attached.
It was confirmed as instructed but does not work.
http://www.diablosport.com/forum/viewto ... 44&t=47489
I tried the 1t03xa to mimic this forum.
But,Symptoms did not change.
What should I do next step?
Re: "Error Code=0x00000386"
what vehicle?
please post the info.xml file from the intune drive along with any files from the runtime folder.
pacificcoast
Hi Mikel,
We have a 2006 TRAILBLAZER SS.
Please Investigation.
Reagards,
runtime_05.dbg
(149.65 KiB) Downloaded 129 times
runtime_04.dbg
(149.89 KiB) Downloaded 178 times
runtime_03.dbg
(147.7 KiB) Downloaded 201 times
runtime_02.dbg
(165.63 KiB) Downloaded 190 times
runtime_01.dbg
(148.06 KiB) Downloaded 163 times
runtime_00.dbg
(149.64 KiB) Downloaded 228 times
info.xml
(2.52 KiB) Downloaded 174 times
Last edited by pacificcoast on Tue May 27, 2014 11:38 pm, edited 2 times in total.
please load the attached file to the intune drive, and let the tool import it, then try it again in the truck.
GM_TUNES-1t02aa.ITF
(5.71 MiB) Downloaded 176 times
pacificcoast
Mikel,
I've attached the GM_TUNES-1t02aa.ITF file, but the symptoms did not change.
I tried to test the other new i-1000 .
It was working properly .
Is it possible to format the i-1000 that has a problem?
Last edited by pacificcoast on Tue May 27, 2014 11:39 pm, edited 2 times in total.
pacificcoast wrote:Mikel,
Is there a new runtime (_06) now?
Can you post that with the new info.xml file please?
pacificcoast
Mikel,
Please check it.
My Best Regard,
runtime_00.dbg
(149.64 KiB) Downloaded 165 times
runtime_01.dbg
(148.06 KiB) Downloaded 184 times
runtime_02.dbg
(165.63 KiB) Downloaded 136 times
runtime_03.dbg
(147.7 KiB) Downloaded 166 times
runtime_04.dbg
(149.89 KiB) Downloaded 131 times
runtime_05.dbg
(149.65 KiB) Downloaded 141 times
runtime_06.dbg
(145.66 KiB) Downloaded 148 times
runtime_07.dbg
(150.22 KiB) Downloaded 128 times
info.xml
(2.54 KiB) Downloaded 123 times
pacificcoast
Would like to ask the reset tool of problem solving if difficult.
Regards,
if you would like to try resetting it please give us a call with it powered up ion the truck.
