How To work the Adjustable Parameters
Re: How To work the Adjustable Parameters
please post the tunes from the tunes folder and we'll make you a custom tune to correct for the new gears.
This custom tune, will I be able to take that peramator out if I dont need it?
What can be done to correct the read back on the log info, As I stated I recorded the engine information and it would not play back, I would like that to work......
http://www.diablosport.com/forum/postin ... 57&t=47864#
billfromislip
Not sure what I'm doing wrong, but could someone explain how to disable esp? I set the option in quick adjust, but when it tries to apply it, the red progress bar stops at 10% and I get an error saying it cannot save parameters. Has anyone else experienced this?
I have a 2014 100th anniversary edition Charger R/T with the 91 octane tune (which feels great BTW)
load this update then try again pleasebillfromislip wrote:Not sure what I'm doing wrong, but could someone explain how to disable esp? I set the option in quick adjust, but when it tries to apply it, the red progress bar stops at 10% and I get an error saying it cannot save parameters. Has anyone else experienced this?
The Tune you will build will be an Option I can pick when I am ready.....?
And I can take it out if I need to for whatever reason?
Here is what is in the tunes folder:
PCM_12607054_backup.grg
PCM_12607054_lasttunewritten.grg
The files will not copy and paste, they will not drag over and drop into this note.
This is becoming extremely frustrating; I ask question, don't get a straight answer; the product does not have what you said it would have on it.
You might understand all this stuff, but some of us out here are not tech wizards !!!
Also, you have not answered my question about the log. It will not play back.
billfromislip
Thanks for the quick reply. Finally got around to trying it, but I get an error message when I try to update it. It autoupdated when I first plugged it to my PC before I could copy this file to it.mikel wrote:load this update then try again pleasebillfromislip wrote:Not sure what I'm doing wrong, but could someone explain how to disable esp? I set the option in quick adjust, but when it tries to apply it, the red progress bar stops at 10% and I get an error saying it cannot save parameters. Has anyone else experienced this?
ok, y is current, no need for yh.
Mikel Please Respond To My Last Post
Im not sure in understand your question exactly?
this is my post:
it was in response to your request for information...
I dont understand how the files will not copy/paste or drag/drop?
thats a function of your PC, not the intune, feel free to call in and I'll have our guys remote into your PC and show you how to do whatever it is you need to do.
