14 Ram 1500, Where did I go Wrong With my Update?
Re: 14 Ram 1500, Where did I go Wrong With my Update?
do you mean only when a tune is installed, or only when the device is plugged in?
ramathorn14
Only when a tune is installed is when my gauge cluster won't shut off and you see what you see in the video.
I plugged my programmer in yesterday but didn't install any tunes and the gauge cluster shut off properly
We'll have to look into this.
Did you make any adjustments when the tune was installed?
ramathorn14
No I only installed economy tune and made no further adjustments to it
try one of the performance tunes to see if its any different.
ramathorn14
Okay I will as soon as I'm out of class today and let you know what's up.
ramathorn14
So this is what's up.
On every single tune installed I discovered that the gauges won't go out ONLY when the programmer is in monitoring mode.
But when a tune is installed and the programmer is left at the main menu, when the truck is turned off the gauges go out and the programmer programmers screen eventually goes black.
OK, thakns for the feedback, I was sure there had to be more to it, is this an 8 or 6 speed Ram?
ramathorn14
OK, we'll have to try to duplicate this.
For now, go to options/set sleep monitor and set it to 0 seconds and see if that helps.
ramathorn14
Done, what will this accomplish?
hopefully it keeps it from keeping the dash lit.
ramathorn14
Actually that might have fixed it
