2008 ford f-150 FX4
aledevil
2008 ford f-150 FX4
Post by aledevil »
Hi!!
I got a problem with my U-7151 (has the last revision), I want to make a change in my tune, it stay freeze when I have to switch to ON, and say make sure the ignition is ON..
What could be the problem???
thanks!!
Re: 2008 ford f-150 FX4
this happens in the performance tune menu?
have you tried starting with the key on?
aledevil
Post by aledevil »
Happends at the momnet when the predator is going to make the orginal backup...
aledevil
Post by aledevil »
I unistall to make service, and when I gonig to make the original backup, say switch to ON, then stay freeze ans say make sure the ignition is ON
sounds like a problem with the tool, id suggest sending it in for a fix.
aledevil
Post by aledevil »
ok mike, exist another way, because I´m from another country...
exist the form that can you send me a update or something?
no, it needs a physical fix.
Return to “Predator Ford Gas”
