Hi!!
I got a problem with my U-7151 (has the last revision), I want to make a change in my tune, it stay freeze when I have to switch to ON, and say make sure the ignition is ON..
What could be the problem???
thanks!!
2008 ford f-150 FX4
Re: 2008 ford f-150 FX4
this happens in the performance tune menu?
have you tried starting with the key on?
Happends at the momnet when the predator is going to make the orginal backup...
I unistall to make service, and when I gonig to make the original backup, say switch to ON, then stay freeze ans say make sure the ignition is ON
sounds like a problem with the tool, id suggest sending it in for a fix.
ok mike, exist another way, because I´m from another country...
exist the form that can you send me a update or something?
no, it needs a physical fix.
