ALREADY REPLACED ECM N NOW ITS DONE IT AGAIN!! DEAD N WATER!
Re: ALREADY REPLACED ECM N NOW ITS DONE IT AGAIN!! DEAD N WA
hey mike it made it in today about mid day so thats awesome for starters. no here is were it gets questionable, the paper says everything was good n all. so i went out and installed the ecm back on my truck, hooked the batteries up, and turned the key and bam....same thing .... nothing. just like it was before i sent it to ya. do i need to hook up my predator and reinstall the original back up or something? or is there something else goin on? also, when should i be expect the charges to be billed to me? havent seen anything about that either since when i filled out the form ....
well, are you 100% sure everything is fully plugged in/connected properly?
When you try to start it, is there a theft/security indicator on the dash flashing or lit up solid?
tech@diablosport.com
its posting up service brake system on the dash mike. as far as i know everything has good connections. im on phone now call yall waiting for someone to answer hopefully...
i got it mike !!! i went back out and looked over every lil thing .... i ended up pulling ecm fuse and forgot to re-install it. put it in and it fired right up!!!!! man i cant thank yall enough !!! specially u dude lol thanks for taking care of all this. customer service is awesome .... but i would like to know about the billing when u get chance . thanks again !!!!!
whew...you were bugging me out man!
I was running around making sure they tested the PCM, they were telling me 'no way, it was fine'...glad it worked out
no charge, this shouldn't have happened.
Man thanks again Mike and the rest of yall for doing a great job of helping this guy out !!! when i decide to upgrade ill def keep diablosports in mind. i def give customer service a 10 in my book, even if ya do have to wait a while on phone sometimes lol none the less thanks !!!
