Issues after update.
dlar00v
Post by dlar00v »
2006 300C SRT8. Trinity. Updated to the latest update (1r12 (1) crom) now it will not read any SD cards. Tried 3 different ones with the same result. The Trinity will tell me that there are no SD cards inserted. Also, when doing quick adjusts there is no save button. I just have to keep hitting back and then eventually it says something about cancelling adjustments I just made and I'm forced to hit okay.
Re: Issues after update.
nothing in the QA menu has changed, what version were you on before?
dlar00v
Post by dlar00v »
I'm not sure what I was on before. Last update was around March I believe. Another question for you on the auto up shift. Last night I tried all 3 modes and stock. None will auto up shift but let me see if I'm thinking of this right. I want the car to auto up shift at red line when in manual mode. So I'm doing a 30mph roll and I down shift into first. With auto up shift, Shouldn't it shift through the rest of the gears without me having to manually do it?
garrett
Site Admin
Post by garrett »
if you set the autostick optinos in the adjustable parameters it will disable the auto upshifting that the vehicle has standard. restore the adjustable parameters and it will go back to shifting the way it was from factory. This is assuming you had the auto upshifting from factory, not all vehicles do.
