power puck causing codes to pop up on 06 cummins
will785
Post by will785 »
So I was driving into work this morning running a power puck on my 06 cummins with the switch in the 90hp position. I was just cruising with traffic when the check engine light came on and I lost all power pretty much.
I read the codes and got p0238 turbo/supercharger boost sensor A circuit high and I got p0113 Intake air temperature sensor 1 circuit high input.
I cleared the codes but havnt driven it since I had to get into work.
The is the first time driving with this unit on my truck.
any help would be awesome.
thanks
will
Re: power puck causing codes to pop up on 06 cummins
did you buy it used or new?
any corrosion on the connectors?
will785
Post by will785 »
got it from a buddy so it was used. ill check and see if there is any corrosion on the connectors. im pretty sure when I hooked it up yesterday the plugs looked good but ill look again.
will
what year was it installed on previously?
will785
Post by will785 »
06 also. I also have a diablo predator from the same guy but I need to do a reflash cause im getting a error saying I need to have the dealer update.
should just need to update the device to the latest versions.
