2013 Durango R/T
johan
Re: 2013 Durango R/T
Post by johan »
Try this file and make sure to reset your parameters when you load this one in and let us know, thanks
pcm_68170468ab_perf_93oct_001.drg
(86.74 KiB) Downloaded 215 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
sprintertech
Post by sprintertech »
johan wrote:Try this file and make sure to reset your parameters when you load this one in and let us know, thanks
thx Johan....i will try this tonight!
sprintertech
ok put the new tune in and it works fine until you attempt to disable mds...then once again it sets a code for bank 2 knock sensor....no audible knock present!
please post a new copy of the last tune written.
sprintertech
mikel wrote:please post a new copy of the last tune written.
PCM_68170468AB_pcm_68170468ab_perf_93oct_001.dr_modified.drg
(5.25 KiB) Downloaded 272 times
sprintertech
mikel, johan....anything on this one?
sorry, Johan is out this week, we'll have to sort this out next week.
sprintertech
mikel wrote:sorry, Johan is out this week, we'll have to sort this out next week.
ok....hopefully something this week.....
sprintertech
ok mikel, johan.....any thing on this problem?
sprintertech
ok are we going to address this problem or not......
it will be fixed in the tunes in the next update.
fixed here, update the tool and it should be good to go, sorry for the delay.
trinity_dcx_gas-1t12ah_update.crom
(10.47 MiB) Downloaded 205 times
sprintertech
mikel wrote:fixed here, update the tool and it should be good to go, sorry for the delay.
ok mikel....ive tried several times to out the file on the tool and for some reson the computer/updater (i think) see this as the same file as before because when i browse for it all that comes up is the old files we tried before.....what am i doing wrong?
if you dont see it on your pc, i am not sure....save it to your desktop then send it to the tool.
sprintertech
mikel wrote:if you dont see it on your pc, i am not sure....save it to your desktop then send it to the tool.
ill try again tonight....may have time....but when i browse with the updater it does not show up even if i know the file location and can see it......
