Is the analog input really 0-5v?
General Trinity Support
cmn1
Post by cmn1 »
I have installed a new AFR Monitor and when I do the math for the analog output to the Trinity and use the manufacturers formula the math reads correct but the Trinity does not. It's off by a full point. If set the analog input settings to read from 1v parameter it is much closer to the math and what the monitor is reading. What gives?
cmn1
Re: Is the analog input really 0-5v?
Post by cmn1 »
So upon further testing. I made a test gauge that reads volts. I have 4.3v on the pin of the cord. When I plug it in I only show 3.4v. Is there a way to calibrate the Trinity? Is this something that needs to be sent back to Diablo for.
you mean you are measuring 4.3 at the cable and the tool is only showing 3.4?
cmn1
Post by cmn1 »
mikel wrote:you mean you are measuring 4.3 at the cable and the tool is only showing 3.4?
That is correct. Trinity gauge is set up to do 0-5v. My meter at the plug before I plug it in reads 4.3v which corresponds to the air/fuel monitor and their math scale.
I cant say I have ever seen this. Check to make sure the cable is seated properly in the receptacle.
cmn1
Post by cmn1 »
mikel wrote:I cant say I have ever seen this. Check to make sure the cable is seated properly in the receptacle.
Channel 2 works fine with my Fuel pressure. I will try putting a/f on channel 2 and see if that does it also.
cmn1
Post by cmn1 »
So test #2. Oxygen sensor out of exhaust, reads 4.5v and not plugged into Trinity. Plug into Trinity and voltage drops to 3.8v. That can't be voltage loss because it reads the same at the plug before I push it in(4.5v).
did you try it on the other channel?
cmn1
Post by cmn1 »
mikel wrote:did you try it on the other channel?
Found out the reason you have never had this problem before, it's because it isn't the Trinity that was the problem. The monitor I was using reads the right voltage when it is unplugged from the Trinity, when I plug it in the voltage drops. So I took a dcv signal generator and check from 0-5 volts with it and the Trinity reads it fine. Thanks for trying to help, Mike.
ahh, good catch :)
Return to “General Trinity”
