I have the Diablo tune installed, can i modifie that tune using the adjustable settings
like adjust stock tune ? for fuel, timing and rpm's ?
Diablo tune
Re: Diablo tune
you can if you really want to, you re not likely to find any gains of our dyno developed tunes however
Re: Diablo tune
I recently installed a cam and headers and dual 2.5 exh. that's why i asked.
going on a dyno when the weather is better
Re: Diablo tune
You need a cmr tune for that, the params are not enough to dial in a cam by any means
BlackZ71Silverado
Re: Diablo tune
mikel wrote:you can if you really want to, you re not likely to find any gains of our dyno developed tunes however
That's quite the statement!
After reading that post, I have to ask................What exactly is the point of "adjustable parameters" if there is nothing to gain or improve on?
Canned dyno tunes are a great starting point but no two vehicles perform the same, ever. Same engine/transmission combo or not, there will be slight differences.
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
MBRP exhaust
GMPP exhaust
GMPP CAI
Re: Diablo tune
There are lots of good reasons for them....from pulling timing for N20, to adding fuel for some airflow mods, or making specific changes you desire, but adjusting the WOT spark and fueling with no good reason or datalogs and AFR data that tell you where you are, leaves you with no idea which way to go
If you wanted to get on a dyno to see if you could find some power from adjusting timing or fuel thats fine, as you'll be able to see the effect of the changes in power output, but I really doubt there is much left on the table
Re: Diablo tune
I do have a wideband gauge in my truck to work with. just trying to get a half ass tune for now,
to damm hot to get a dyno tune. it would be a waste of money and would have to be retuned
later on.
later on.
Re: Diablo tune
OK, you'll be able to dial in WOT fueling with the wideband, but getting AFR at part throttle and idle is going to require custom tuning.
fastzenner
Re: Diablo tune
How do you change the units on intune, I haven't figured it out or can you even ? Like instead of kpa maybe psi? Or Lamba .78070 to 12.5, mph to kph? And also I have a TSS tune and wondering if there's a ghost cam for 3.7l mustang yet?
Re: Diablo tune
I think you can change over in the settings section
Re: Diablo tune
the values can be changed in dataviewer for playback.
no ghost cams for V6, we tried, it did not like it, or sound good
