I have a i1000 tuner with a custom tune. I removed the tune to help with some troubleshooting. Then when I went to reload the tune, the tuner turned off mid write. The truck wouldn't start, reboot the tuner, it's in "recovery mode," follow the prompts it goes through, makes it through the writing process for the PCM, but for the TCM it fails.
Now no matter what I do, the tuner boots into recovery mode, click the prompts, it begins to go the TCM process. I get to the point were you cycle the key, and as soon as you press the check mark to continue, the tuner shuts off. It does this repeatedly, I've probably tried no less then 50 times with the same results.
Any idea what happened? I can't load my custom tune, the TCM tune, only god knows whats in there. The truck runs a little goofy and shifts all weak and soft.
You can see what it's doing here:
https://www.youtube.com/watch?v=QaWgMjnP6GQ
I don't know if it's a hardware issue or if there is something I can do to make it work.
Stuck in recovery mode, turns off mid TCM write.
Redsand187
Re: Stuck in recovery mode, turns off mid TCM write.
please post the info.xml file from the intune drive, the backup for the TCM from the tunes folder, and any files in the runtime folder on the intune drive, and we'll get you going.
Redsand187
Attached are the files, I don't see a runtime folder anywhere.
2005 Dodge RAM 5.7hemi auto 4x4.
Redsand187
we need to update the tool to get a runtime, save this to the intune drive and let it import the file then go to the truck and trey the restore again, when it fails, it will make a runtime file.
CAN YOU HELP ME OUT TO SAME PROBLEM. 2013 CHRYSLER 200 3.6
I have run into the same issure with my JGC SRT8. I will call dec 28 as I am flying back home and wont have access to my vehicle for a week
MIKE.MCCONAHA
i have a simular issue only it has locked or fried my first pcm. now on a 2nd pcm and it got stuck in recovery mode while trying to update the calibration for the pcm. i do know under the delete vin option there are 2 vins one is mine and one is another vin simular only last 6 digits are different. the current pcm still works are the car starts. really just wanting to install the 93 tune and get it fine tuned.
