No cdrom or Intune.exe
danimal666
When i plug in the Intune, it doesn't update or show the intune.exe
I have a folder named: logs, which is empty.
And a folder named: tunes, which is also empty.
There is an info file, and this is what is contained in it. PLEASE HELP!
- <tool_info>
<main full_version="InTune-1r03j 05/29/2013 01:30:58 PM" sw_rev="1r03j" svn="6254" />
<registration sn="JNK3T13-6" status="0" />
<cal_id PCM="04896414AF" CM1="04896850AC" />
<restore id="0" vin="2D4FV48VX5H581614" bc="0" />
<system_db info="1r01b" dtc="1r01a" vin="1r01c" />
<db mfr="DCX" tune="1r01b" pid="1r01a" />
<db mfr="FORD" tune="unknown" pid="1r01b" />
<db mfr="GM" tune="1r01r" pid="1r01a" />
<license avail="1" tuned="0" />
<updates count="1" />
<oem tool_oem="DIABLO" />
</tool_info>
- <tool_info>
</tool_info>
- info.xml
- This is the info file.
- (508 Bytes) Downloaded 368 times
Re: No cdrom or Intune.exe
save this to the intune drive then the cd rom drive should appear.
- cdrom-1r01p.itf
- (5.39 MiB) Downloaded 697 times
danimal666
Ok...i did that and it said writing. When the Intune drive opened back up, it doesn't show any change in the file folders and there is still no cdrom or intune.exe either. Is it possible to mail this to you guys and you can just reformat it or something?
It would be another drive called diablosport, no ton the intune drive itself, do you have another pc you can try it on?
danimal666
The only place i find Diablosport is in my list of 'All Programs'. When i click on it, it shows DataViewer 3.3 and Uninstall DataViewer 3.3
I don't understand why there is nothing on the Intune itself...it's acts like an Ipod with no Itunes on it.
there is not supposed to be anything on the intune drive sir, there is no problem there.
the diablosport drive is not some file on your pc, it is listed under computer as a CD ROM drive, called diablosport.
danimal666
That's what I'm telling you...it's not there.
If you cant see it on another PC, please fill out the return form on our site and get it sent in for a check up.
danimal666
I called tech support, they got me squared away. Thanks for helping, but it needed files sent by email.
Cheers!
Cheers!
TheRockstarNerd
Care to share those files? Can't seem to get my firmware squared away.
sgt_goldburg
I have no intune.exe file. can you please send it to me?
that cant be sent...try a different PC maybe?sgt_goldburg wrote:I have no intune.exe file. can you please send it to me?
