2014 Mustang 5.0
armyguy202000
2014 Mustang 5.0
So I have a 2014 5.0 3.73 gears, JLT CAI, Flowmaster super 44'axel back and that's it. Im running the JLT 91 octane tune. When I go to adjustable parameters the gears are set at 3.31 I believe. If I change to 3.73 will everything else stay the same. Also is there anything else I should adjust I only ask because I don't notice much if any difference in performance. Thanks
Re: 2014 Mustang 5.0
Please post your last tune written out of the tunes folder.
Insert Clever comment here...
armyguy202000
ok
- PCM_FPFD32A_LastTuneWritten.frg
- (592.97 KiB) Downloaded 211 times
armyguy202000
any thoughts? I saw a few forums you helped some guys out in before. Hope to get the same results. I can really tell the difference since I changed to 3.73 gears on the tune I posted. Gas milage sucks though on the highway im only getting 16-17. However, I didnt buy a 5.0 for the gas milage just think its bad based on the post of others.
Here you go sir. Sorry for the delay.
- pcm_fpfd32a_r2.frg
- (549.99 KiB) Downloaded 215 times
armyguy202000
I am running the last tune that you sent me and when I come to a stop when my engine is cold my car will die. Also if I let it sit and idle for to long the idle will start to go up and down by 2-3 hundred rpm. I have also added an x-pipe by Pypes but it was doing it before the addition.
Try that
- pcm_fpfd32a_r2b.frg
- (550.08 KiB) Downloaded 278 times
armyguy202000
Attached is the data log after running the tune you just sent. Please review.
- 1ZVBP8CF6E5281117_01.log
- (1.7 MiB) Downloaded 207 times
armyguy202000
I am adding shorty Flowmaster scavenger series headers today can you adjust the last tune if needed?
shorty headers will not require any changes ideally.
armyguy202000
Something is going on. Since I added them when cold started I get the loud pop noise from my JLT CAI like before adding the tune for the CAI. Then after warm and sitting at idle for more than a min or so idle starts to fluctuate to the point of almost dieing.
burn up an O2 harness?
Post what's in the tunes folder on the tool currently.
armyguy202000
This is the current tune im running
- (550.08 KiB) Downloaded 229 times
