2014 Dodge Charger 100th AE edition
I keep getting a PCM Calibration Update Issue While trying to write a tune. Have removed unit 3 times & plugged back to PC for update but its not working same thing every time info file says CAL ID Unsupported. Could use some Technical Support help?
PCM Calibration Update Unsupported
- info.xml
- (2.05 KiB) Downloaded 266 times
Re: PCM Calibration Update Unsupported
Looking into it...
tbriggs2001
Receiving same as above but with a CAL ID: 68172057AF This is on a 2014 Dodge Durango 5.7.
Same problem. Same code: 68172057AF
New 2014 Dodge Durango Citadel 5.7L
No modifications. Never been programmed.
Thanks for your help.
George
George
that has not been added to intune yet, should have an update later today.
Thank you Mike M. In tech support for your help with this problem. He provided a fix first thing in the morning after I sent him my info file at midnight the night before.
If anyone still has problems with this, please contact tech support. They will take care of you.
Thanks again,
George
Thanks again,
George
