2012 Jeep Wrangler Transmission issues
doz
Post by doz »
So I had my Trinity on my JGC for awhile. Worked great, no issues. Uninstalled as I traded it in. Updated the tool with the latest updates, changed the vehicle selection to a 2012 Wrangler, and installed the 91 tune.
After the tune, the car will go into a limp mode after about 30 seconds. It will lock into whatever gear you are in at the time (usually 3rd by then, but its done it in othe rgears). I cannot manually change gears (auto tranny w/ "manual" mode). I must turn the car off and restart it and it will be back to normal for another 30 seconds. The CEL illuminates but will not give me a code.
Tried reinstalling the tune to no avail. Any suggestions?
Re: 2012 Jeep Wrangler Transmission issues
did you swap rear end gears?
doz
Post by doz »
Gears from the factory are 4.10. Maybe thats the problem? I checked the gear ratio and told the 91 tune to use 4.10 gears. Should I have left it alone? It was defaulting to like 3.73 or something.
Yes, do not change that.
doz
Post by doz »
Gotcha alright. Thanks for the info so quickly! May not even need to worry about it now. Might just get thrown into a new 2014 RAM we shall see.
