install problems
rbrewer614
install problems
quick question. I just updated my T1000 for my 05 dodge 3500. Now I can't get pass the select tune stage. it freezes up when it gets to the loading part. Or am I not giving it enough time. before the update it was done it worked pretty quick. Also would like to know if I have to go to a dealer to get some tunes for the add ons I've done such as air intakes and lift pumps.
05 dodge 3500 2wd, 6 spd NV5600, high flow air intake, 3in manifold intake, 2in lift blocks, raptor100 fuel, trinity T-1000, glowshift gauge kit, 5" dual stacks, BW s366 box turbo, 2nd gen swap.
Re: install problems
what is the current version on the tool?
When you say it freezes up, the lightning bolt stops, etc?
rbrewer614
I believe its 2.2.2.6 I just updated about an hr ago.
rbrewer614
lighting bolt?? it shows the download bar over the screen as full but it goes no farther.
rbrewer614
Hey mike is there anyway to access a unit remotely???? So if the problem is in the trinity it could be fixed.
we can try, but we wont be able to change whats going on, do you have a different PC you can try it on?
rbrewer614
Garret its up and running, and had no issues!! Thanks so much I was getting worried.
