E85 in 2014 LT1 or L86?
typhoon186
Is it possible to run 100% E85 fuel in a 2014 LT1 (C7) or L86 (truck) with only a custom tune? They are not flex fuel engines. Has it been done successfully?
Re: E85 in 2014 LT1 or L86?
if tuned for it, yes, it will work fine.
typhoon186
That's good news. I expected some mechanical parts would have to be different or upgraded.mikel wrote:if tuned for it, yes, it will work fine.
Have you guys tuned one for E85 yet?
No...we haven't.
We have run our Cadillac ATS 2.0T (non flex) on E85, and even converted one to work with the OEM flex fuel sensor.
typhoon186
Don't think I want to be the first.
Sounds promising for a hot tune though.
there is a fuel sensor in the fuel line that tells the PCM what amount of E85 is running
thru it and the PCM makes the adj to the eng for it. also diff pump and injectors.
