Hi guys,my predator tomorrow dont work!! the display show this: the original backup is not saved(-12)?? CONTINUE, unit 1: error unlock(-1), CONTINUE, predator will now make a 2nd backup attempt.
WHAT'S UP?
U7145 and 08 Mustang
Re: U7145 and 08 Mustang
did it work in this vehicle previously?
If so, what changed?
No Mikel !! this before is maried with other car, pay unlock and I use the predator a new car!!
Hi guys ,please give a solution for my problem? test and check the car or the Predator? Thank you
Im not sure why it will not save it, do you have a way to have the pcm flashed by a dealer to make sure it is all stock?
Ok tomorrow check this solution!! thank you Mikel
Hi Mikel, today I tested my car in FORD but the problem remained! do you have any solution?
this predator was unlocked June 20 and tried two weeks ago, is possible predator damaged? Thank you
Hello!!someone can answer to my problem? thank you
what vehicle are you trying it on?
2008 febrary Mustang V6
I am not sure why the tool will not read the backup.
it might be worth a shot to see if the dealer cal flash the car then see if the tool works.
