Timing curve???
rap-1
Timing curve???
Post by rap-1 »
Is there anyway,we can advance the timing curve w/the pred,to produce more power,has anybody tried this???
Torrid
RE: Timing curve???
Post by Torrid »
Yes, there should be a option in the modify tune area called WOT spark with adjustments from 0-4k RPMs and 4k-7k RPMs depending on vehicle.
sickREDsierra
RE: Timing curve???
Post by sickREDsierra »
there is an option to adjust from 2k-4k, then 4k-7k rpm. just make SURE you monitor after EVERY adjustment for KR at WOT.
you better make sure you run the best gas you can find if you are gonna advance it, and keep a close eye on KR.
good luck with it. :wink:
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
Return to “Predator GM Gas”
