2014 F150 Tremor 3.5
sarah_ima64
Post by sarah_ima64 »
My new F 150 tremor I don't feel stronger
I install 87 tuned (with premium fuel 92 oct)
when shifting i had 3 degrees knock also 0 to 60 it doesnt work, never read speed
I need help, i want run 91 performance
also my f150 only has 400 km
PCM_KGCV2V4_87_Performance_modified.frg
(10.25 KiB) Downloaded 313 times
PCM_KGCV2V4.frg
(169.15 KiB) Downloaded 356 times
2005 RAM 1500 Daytona : Diablosport Trinity, CAI Airaid, Headers JBA, Catback Borla.
2009 RAM 1500 SLT 4x4 : Diablosport Trinity, CAI Airaid, headers JBA, Catback Flowmaster.
2011 RAM 1500 Laramie 4x4 : Diablosport Trinity, CAI Airaid, Catback Magnaflow.
sohfast94
Re: 2014 F150 Tremor 3.5
Post by sohfast94 »
Go to options - show version and tell me what it says. The tune loaded perfectly
Also what did you modify on the tune? Do you have any logs?
Insert Clever comment here...
sarah_ima64
V.1r12a
Sabes calid KGCV2V4
I have 2 logs
sarah_ima64
Can I install intune ?
I don't need trinity on my tremor
I prefer trinity on my ram
sohfast94
Post by sohfast94 »
Update your intune via the updater and then drop this on there after it's all done. Then you're good to go.
FORD_TUNES-1t01ta.ITF
(14.31 MiB) Downloaded 331 times
sohfast94
Post by sohfast94 »
... of course make sure you return to stock with your trinity first... 8)
sarah_ima64
I have still knock, when shifting
Gas 92 oct
only changed speed limiter off
PCM_KGCV2V4_LastTuneWritten.frg
(144.58 KiB) Downloaded 300 times
PCM_KGCV2V4_Backup.frg
(144.53 KiB) Downloaded 324 times
1FTMF1ET8EFB36504_00.log
(2.39 MiB) Downloaded 309 times
sohfast94
Post by sohfast94 »
Load that and run again.
pcm_kgcv2v4_R2.frg
(127.95 KiB) Downloaded 317 times
sarah_ima64
This tune is for premium gas ?
here mexico only max octane is 92 , I only use 92
I try this tune this afternoon
Thanks for your help
Diablosport is the best
sohfast94
Post by sohfast94 »
Its basically your tune you posted with the timing adjusted.
sarah_ima64
I upload the custom, When I want to install does not appear on the write
sarah_ima64
I resolved knock, only add fuel 10%
my tremor is fast
before to tune ran 6.89 0-60 MPH
after to tune ran 5.95 0-60 MPH
sarah_ima64
thats fast :)
a full second improvement in 0-60 is great!
sarah_ima64
Its a incredible
Thanks for you product it's the best
Return to “Trinity Ford Gas”
