pentastar 180 thermostat fan setting
RuffRider
Re: pentastar 180 thermostat fan setting
Post by RuffRider »
Well the "mega crom" 12 didn't work adjusting the fans. They still come on at stock 220+ settings.
2012 JKU RUBICON 5WA580 5 SPD AUTOMATIC
Will the above mentioned
trinity_dcx_gas-1t12bb_update.crom (10.39 MiB)
correct this so I can drop the fan settings as needed??
2012 JKU RUBIKONG: Far too much to list here...
RuffRider
Post by RuffRider »
Good Morning,
Any news on correcting the 2012 ++ fan settings?
I was told 1.5 weeks ago by your tech department that you had a JK in and were testing it. It's been really hot and humid lately and it would be nice to take advantage of the 180* stat...
RuffRider
Post by RuffRider »
Stone silence...!
I guess "soon" means within the next decade?
Yes
Post by Yes »
Any news?
Yes
Post by Yes »
Hello?!
RuffRider
Post by RuffRider »
Echo, echo, echo......................?
johnny248
Post by johnny248 »
mikel wrote:lower them all by the same amount, about 20*
Hey Mike, this is a little off subject , but my I installed a 190deg T-stat in my '11 Ram Hemi (Just wanted to avoid some of the issues some people were bringing up with the newer style trucks and 180 stats. The 190 seemed like a good choice since it is 13deg less than stock, but not low enough to possibly cause threshold errors) and removed the clutch fan. Truck originally had a 203 stat from the factory. I set my cooling fans under all settings to turn on at 199.something. I just made that number up thinking 10degs over the thermostat setting should be acceptable. Am I wrong in my thinking? Should it be something else? While driving, the natural air flow allows my truck do cycle nicely from 190 down to the low 180's and then back up like it should. Only time the fans come on is if the A/C is on, or if I am sitting at a stop light or something.
Are my settings good? Or should I have them set differently?
'11 Ram 1500 Quad Cab 4x4 5.7l Hemi
ma7romal7ob
Post by ma7romal7ob »
I am about to install my new rpp 180 thermostat to my jeep jk 3.6, can you please advice me what is right fan setting for the new satat? the stock thermostat is 209 F and the new one is 180 F, should i lower all of the fan setting by 29 degree or what you recommend me to do?
thanks
zeyad aldamegh
Post by zeyad aldamegh »
ma7romal7ob wrote:I am about to install my new rpp 180 thermostat to my jeep jk 3.6, can you please advice me what is right fan setting for the new satat? the stock thermostat is 209 F and the new one is 180 F, should i lower all of the fan setting by 29 degree or what you recommend me to do?
thanks
Hey just forgot it for now at least I am facing the same problem you have. The fact diablosport doesn't support fan settings for new jk with 3.6 pentastar. I have been waiting for fix from them since December 2013.
Bel3arabi 3yal alkalb na9abeen.
ma7romal7ob
Hello ...
Is the respondent or not ...
must respect people's views and not neglected ...
there is an update in testing.
ma7romal7ob
Programming custom by car and not programming Diablo ...
What is required adjustment of the fan ...
zeyad aldamegh
Pump
A new update has been released that has the new fan parameters added.
zeyad aldamegh
mikel wrote:A new update has been released that has the new fan parameters added.
Nice good yo hear that.
