newbie lost :)
newbie lost :)
I have just bought a 99 Camaro ls1 that has no cats, has the trinty tuner and still don't see the power like it should. any help would be greatful before I play with the tuner for months.
Re: newbie lost :)
what are you expecting, or what do you feel is missing?
does it run OK with the stock tune?
Re: newbie lost :)
it seems to have power at low end then around 4000 is flat then picks up a little. I cant get stock tune to load back so im not sure there. also first gear shifts kinda late at part throttle. was hoping you would notice something from the log I sent you.
should a stock or automatic tune be set on the trinty to use? I use the diablo tune only because others will not load. I bought the car like this, so don't know much about it.
Re: newbie lost :)
are you sure the tool is married to this car?
If it wont restore, something is odd.
Re: newbie lost :)
what is the version on the top line of the main menu?
Re: newbie lost :)
serial 6qhhzde-4
gm-11850
hardware trinty
v.1rl2
born 6/02/2014
bus test not done
saved calid 360361357561
gm-11850
hardware trinty
v.1rl2
born 6/02/2014
bus test not done
Re: newbie lost :)
ok, go to options./show last tune written, what does it show there?
Re: newbie lost :)
9360361 main os
9357561 eng
9357893 eng diag
16264230 trans diag
16264562 fuel system
9357561 eng
9357893 eng diag
16264230 trans diag
Re: newbie lost :)
Theres your problem. With no cats, you're gonna need a custom tune, not a modified canned tune.
Re: newbie lost :)
Gotta talk to a CMR tuner. Not sure if Lew is back to doing tunes again, but if he is, he's your man. www.diablewtune.com
Re: newbie lost :)
yah lew not avalible. sorry to hear about him.
