ABS light after tire adjustment - HELP!!!
BlackOverlandHemi
I adjusted my tire size (bought larger tires) and now have ABS light. I tried the adjustment with my custom tunes from hemifever, and also from stock. Both have left me with the light on. What do I need to do to fix this? I've search forums and followed instructions from them with no luck. One example is adjusting the size unplug reinstall tune and adjust again with no luck, did this both with custom and stock. Info: Version v.1r12a dcx_gas - 2012 Grand Cherokee Overland Hemi. Please Help!
Re: ABS light after tire adjustment - HELP!!!
does it go out if you restore the stock settings?
BlackOverlandHemi
No it stays on
please go to options/troubleshooting/show calid and let me know what it is.
BlackOverlandHemi
PCM 68111691AE
I believe I'm currently set on my hemifever tune with the tire change. I had changed it around so many times and the ABS light wouldn't go away so I believe I said screw it and loaded the hemifever tune back on with the change, but I can't say for sure. But what I do know is my speedo was reading correct today, but still with the ABS light.
BlackOverlandHemi
You working on a fix?
Yes, we are looking into it.
BlackOverlandHemi
Any news on the fix?
BlackOverlandHemi
Nothing new? No idea what the issue is?
BlackOverlandHemi
Bump still need fix!!! PRETTY PRETTY PLEASE!!!
there should be a new version out this morning.
BlackOverlandHemi
Thanks can't wait to get it fixed!
BlackOverlandHemi
Is new version out?mikel wrote:there should be a new version out this morning.
BlackOverlandHemi
Is the fix out yet?
BlackOverlandHemi
Is there a fix for my ABS light yet?
