newbie lost :)
thomas73
newbie lost :)
Post by thomas73 »
I have just bought a 99 Camaro ls1 that has no cats, has the trinty tuner and still don't see the power like it should. any help would be greatful before I play with the tuner for months.
KMART.LOG
(21.59 KiB) Downloaded 153 times
FORT.LOG
(46.19 KiB) Downloaded 166 times
DQ.LOG
(274.47 KiB) Downloaded 150 times
Re: newbie lost :)
what are you expecting, or what do you feel is missing?
does it run OK with the stock tune?
thomas73
Re: newbie lost :)
Post by thomas73 »
it seems to have power at low end then around 4000 is flat then picks up a little. I cant get stock tune to load back so im not sure there. also first gear shifts kinda late at part throttle. was hoping you would notice something from the log I sent you.
should a stock or automatic tune be set on the trinty to use? I use the diablo tune only because others will not load. I bought the car like this, so don't know much about it.
Re: newbie lost :)
are you sure the tool is married to this car?
If it wont restore, something is odd.
thomas73
Re: newbie lost :)
Post by thomas73 »
How do I check that
Re: newbie lost :)
what is the version on the top line of the main menu?
thomas73
Re: newbie lost :)
Post by thomas73 »
serial 6qhhzde-4
gm-11850
hardware trinty
v.1rl2
born 6/02/2014
bus test not done
saved calid 360361357561
Re: newbie lost :)
ok, go to options./show last tune written, what does it show there?
thomas73
Re: newbie lost :)
Post by thomas73 »
9360361 main os
9357561 eng
9357893 eng diag
16264230 trans diag
16264562 fuel system
thomas73
Re: newbie lost :)
Post by thomas73 »
pcm diablo modified
Re: newbie lost :)
Theres your problem. With no cats, you're gonna need a custom tune, not a modified canned tune.
thomas73
Re: newbie lost :)
Post by thomas73 »
ok how do I do that?
Re: newbie lost :)
Gotta talk to a CMR tuner. Not sure if Lew is back to doing tunes again, but if he is, he's your man. www.diablewtune.com
thomas73
Re: newbie lost :)
Post by thomas73 »
yah lew not avalible. sorry to hear about him.
