2015 Jeep JK Rubicon Unlimited T1000 Issue
justjeff
Post by justjeff »
Hello,
Purchased a Diablo Trinity T1000 Jeep JK Tuner for my new 2015. I mainly need to adjust for the new tire size. I purchased through a reputable Jeep parts distributor and the add for the tuner stated through 2015 Jeep JK Unlimited. The dealer said they were unable to install the tuner and they had contacted the manufacturer through the numbers on the package. They were told it was not compatible for the 2015 Jeep JKs.
The question: Is it compatible or not. If not should I return it or will there be an update to the program in which I can run my T1000 and make the adjustments in the near future?
Thank you for your time,
Jeff
Re: 2015 Jeep JK Rubicon Unlimited T1000 Issue
we have not released support for any 2015 Jeeps, I cant imagine what add they were looking at ;)
dan
Post by dan »
Hey Diablo Fans!
We noted your interested in tuning your 2015 Jeep Wranglers.
We have found a solution to tuning the 2015 Model Years, but it’s a little different than just using a tuner. It requires an aftermarket PCM as well as the tuner in order for you to do a tune installation. We can provide you all the necessary equipment (PCM and Tuner) to get your 2015 tuned up.
Here’s how it works- we get your vehicle’s VIN and Odometer mileage and we modify a factory PCM at our facility which we then send to you as well as a DiabloSport inTune DCX or Trinity. You would replace your Jeep’s PCM with the Diablo Modified one (it’s only 4 screws to unhook). Once that’s complete, you install the tune with your DiabloSport tuner and you’re ready to go! If you need to go to the dealership for service work, all you would need to do is re-install your original PCM and they will not be able to tell that you have done any modifications.
Pricing for this Program is:
Diablo PCM + inTune DCX: $899
Diablo PCM + Trinity Tuner: $999
Diablo PCM Only: $599 (You would use this option if you already have a Diablo Tuner)
Is this something you would be interested in? If so, please email us at [email protected] or call us at 561-908-0041 ext 1 and reference the 2015 Jeep JK Program for more information and the process to get started.
Sincerely,
Dan Dolan
DiabloSport Sales & Marketing Manager
Phone: (561) 908-0041
Dan Dolan
National Sales Manager
(877)396-6614
