STANT 180 THERMOSTAT
HDSALES
Post by HDSALES »
ican you help me with the settings on this stant 180 thermostat
that I am putting in my truck, I have a trinity t-1000
thanks
johnny248
Re: STANT 180 THERMOSTAT
Post by johnny248 »
HDSALES wrote:ican you help me with the settings on this stant 180 thermostat
thanks
Are you referring to fan settings??? I have a Stant 190 Thermostat in my truck and removed the clutch fan. I lowered the fan turn on settings to 199.something. I figured 10 degrees over the t-stat should be ok. The OEM stat is 203, so I figured that my setting is pretty good unless someone else has some better info than me. Some people run it lower, but they mainly turn on when you are not moving. While my truck is running, say on the hwy the temp always runs how it should thanks to air flowing through the grill and the fan only kicks on if I am sitting at stop lights or something like that. If you are referring to other settings, then I have no idea lol
good luck!
'11 Ram 1500 Quad Cab 4x4 5.7l Hemi
Ramrt1
Post by Ramrt1 »
I would think setting the value to the degree thermostat you have installed would your choice, I have a 180 stat installed and that's where I will be setting mine.
