MDS won't shut off even with 1r13 !!! Charger R/T '13
nescafe4all
Post by nescafe4all »
Hello
I'm trying to disable MDS across the tunes available but it doesn't at all
i tried 91, 93 and even modifying the stock one
i would like to get an update for my trinity rather than modifying the tune it self
Re: MDS won't shut off even with 1r13 !!! Charger R/T '13
what makes you think it is not disabling?
nescafe4all
i have straight pipes and it is noticeable.
i have to kick autostick in order to shut that noisy exhaust sound and yes i can recognise the difference
even fuel consumption gauge changed quickly once MDS is activated
aren't those cases indicate that MDS is on ???
regards
so you set it to off in the tune, then loaded that tune to the truck?
Post a copy of the last tune written please.
nescafe4all
just modified the stock tune for many things including MDS
PCM_68171369AC_Modify_Stock_Tune_modified.drg
(1.25 KiB) Downloaded 178 times
nescafe4all
i forget to mention an issue for Fan setting. it used to work well but not it doesn't !!!
johan
Post by johan »
we will fix that up, attached file has fans dropped and mds off
pcm_68171369ac_modify_stock_tune_001.drg
(69.34 KiB) Downloaded 198 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
nescafe4all
thancx Jhoan i appreciate your help
where did you discover the problem ?
because i'm planning to install 93 oct tune later as i have CAI, but not now. i have to clean the intake manifold before
nescafe4all
I pluged my trinity and been updated to 1r13a
Then u sent the tune that Johan made and i wrote it on the car
MDS still kicks on + fans started at 210 f with AC on while parking in my garage
But while cruising around at 60 MPH the coolant temp dropped to 195 F !!!!!!
I installed the tune straight away without any modification to the parameters, because as far as i believe it looks like a custom tune which i can do nothing to it
nescafe4all wrote:I pluged my trinity and been updated to 1r13a
please export the last tune written and post it up here.
