I want to see my boost meter
jsm11
Post by jsm11 »
Looking for instructions on how to setup my the boost meter for my 2013, ford f150, ecoboost.
I would like to monitor the PSI from the Turbos...
JSM
Re: I want to see my boost meter
there will be a new update soon that added the boost gauge to the layouts.
jsm11
Post by jsm11 »
Understood, please update when available.
JSM
jsm11
Post by jsm11 »
I know getting a time frame out of you guys, is like pulling teeth. I understand why, just curous if it's closer or further away?
the attached update does not yet have the new layouts added, but it will allow you to select the boost PID under synthesized at the bottom of the list and add it to an existing layout or put it in a new one.
trinity_ford_can_gas-1t12ba_update.crom
(3.03 MiB) Downloaded 548 times
ChrisN1313
Post by ChrisN1313 »
mikel wrote:the attached update does not yet have the new layouts added, but it will allow you to select the boost PID under synthesized at the bottom of the list and add it to an existing layout or put it in a new one.
Is this in the newer updates on the trinity? Just hooked one up today on a 11 ecoboost and couldn't find it.
Yes, its been in there for a while, make sure the tool is updated.
ChrisN1313
mikel wrote:Yes, its been in there for a while, make sure the tool is updated.
As far as I know it's updated I hooked it to ds downloader this afternoon and it seemed to update. What's the exact parameter called ?
sohfast94
Post by sohfast94 »
There should be dash that pops up under monitoring called ECO_BOOST and it will have the boost gauge in there.
If it does not show then go to logging -> then all the way to the bottom -> restore default dashboards
Once you've done that it'll show up under montoring and logging for you.
Insert Clever comment here...
hafredd
Post by hafredd »
I see this topic is old. But im trying to get a boost gauge on my Trinity. I updated last weekend. I did what was suggested with no luck of finding a boost gauge.
Thanks in advance
Harold
what application?
have you looked into adding it under the synthesized pid menu?
hafredd
Post by hafredd »
2011 Ford Ecoboost F150. How do I add it under the PID menu?
hafredd
Post by hafredd »
Meant 2012 not 11
hafredd
Post by hafredd »
Ok I got boost to come up and it appears to be working. Is there a way to stop the timer from showing on the gauge? Its the timer that shows the amount of time it's been logging.
you can edit the layout and click on the timer and delete it, then save it with a new name.
Return to “Trinity Ford Gas”
