intune sport not talking to pcm
kevin121987
Post by kevin121987 »
I have had the intune for a few months and have called and talked to many techs. it stopped talking to my PCM. I read on the forum that some others had issues with the 04 dodge ram. one had scanners talk to his truck just like mine, matter of fact the bully dog tuner, super chips tuner, solus scanner, snappon brick, dodge dealer scanner all talk to my pcm. can bring up vin, data logs etc. only the intune will not talk to it. I have sent it back to you guys twice and you reset and tested an said it works fine. but on my truck it will not talk to it at all.
if I hit write tune, turn on key (not crank) the wheel spins for a minute or so then goes back to the menu. if I choose data and hit record, same thing. if I choose tools and hit vehicle info, it spins then comes back on ecu found. every now and then it will say does not support vehicle.
I checked very pin from the obd2 port to the computer and all ohm good. like I said, the other tuners will talk to it perfectly. I ordered a new computer had it flashed to my truck, and still no talking with my pcm.
I would think yep my truck, but with everything else talking to it, I think there is a flaw in the intune. a bug or something. I am fighting this every day. I spend about one to two hours a day rechecking rechecking and cant find a thing wrong.
I wanted to see if anyone is near the Beaumont texas area that would let me meet them and hook your intune up and just run a DTC scan or vin identification test to see if your intune will talk to my pcm.
kevin121987
Re: intune sport not talking to pcm
update on the issue.
after many many weeks of calling and talking to every single tech. after sending the unit in twice for resetting and checking. after being told it is not the intune but has to be my truck. I found 3 people with an inune. they let me try theirs on my truck. All three worked fine. read the vin. checked codes everything. So one of the guys that was fixing to put his up for sale decided to check and see if mine would read on his 05 dodge ram. mine is an 04. it read his. so he cleared his and rest.. mine was already reset from guys at diablo.. so now I am tuning again with the other intune.
I told you that it was not my truck. I spent many hours every week checking and rechecking. if you guys run in this issue again you might want to at least try and swap an intune to see. because there is definitely something wrong with my old intune on the 04 truck.
Return to “General Questions”
