Hi,
I had a 2013 Charger srt8. Had an accident, car totalled. I removed the update from the car using My Diablo Trinity. Returned it to stock.
I got myself a 2014 Charger SRT8. I plugged the Trinity, it said Cal ID not supported... I updated the Trinity to the latest software.
Plugged it in the car, it seems to work. Did a performance tune 93Octane. Tried to start the car, it did not start... kept stalling like there was no gas in the car.
Returned it to stock. The engine started fine.
Any Ideas?
Thanks.
2014 Charger SRT8 Not Starting after 93Oct Update
Re: 2014 Charger SRT8 Not Starting after 93Oct Update
hmm, did you make any adjustments when you loaded the tune?
would you be willing to load it again, then connect to a pc and get the backup and last tune written files and post them here, then restore it?
Actually, after loading the tune, and BEFORE turning the car on, I made some adjustments like increase the REV limiter and Top Speed.
would that cause the issue?
Ok,loaded the 93 tune again without adjustments. It works fine.
What could have been the issue?
Im pretty sure it was the rev limiter. What is the version on the tool?
