2014 Dodge Challenger SXT and Traction Control
Re: 2014 Dodge Challenger SXT and Traction Control
Question for you guys with the TC/ESP disabled tune. Once you loaded the tune, did it also disable your cruise control?
2011 300C-Tungsten, Johan tune, reso delete, Lockpick C8, modified airbox
Can you use this one Mike and turn off the "nannies" ?mikel wrote:this tune is locked, you will need to ask your tuner to take care of this.Smokey613 wrote:Here is mine Mike. Thanks for all the assistance!
Hi Mikel, still doing the custom tune for the ESP turn off issue? If so here is my last written. Thanks
Here you go.Smokey613 wrote:Can you use this one Mike and turn off the "nannies" ?mikel wrote:this tune is locked, you will need to ask your tuner to take care of this.Smokey613 wrote:Here is mine Mike. Thanks for all the assistance!
here you go.Skbarre wrote:Hi Mikel, still doing the custom tune for the ESP turn off issue? If so here is my last written. Thanks
Thanks Mike!
Any news on a fix for this yet? I've now got a custom 91 tune from Sean @ HemiFeverTuning, but would like to be able to go in and disable traction control while using it if I wanted to. Right now I've only got a custom tune that has to be loaded to disable it full time. But this was prior to my custom tune so it is a different set up.
sean can make you a copy of that tune that kills TC as well if needed...
Hi Mikel, would you turn off my TC ?
I am still wating for the update that fix it, but i am afraid that it might take a lot time to make an update to fix this issue.
Thank you.
Thank you.
2013 Dodge Charger SXT 3.6L
here you go.omar0yah wrote:Hi Mikel, would you turn off my TC ?
Thank you.
Thank you mikelmikel wrote:here you go.omar0yah wrote:Hi Mikel, would you turn off my TC ?
Thank you.
Hello,
Same with my 2014 sxt 3.6 with cold air, Do i need to adjust anything else with cai. ?
here you go...slpolson wrote:Hello,
hi mikel, i bought a custom tune from a local tuner, and i asked him to turn of the Traction Control in the tune, and he said that he can't turn it off! and the device (intune DCX) also can not turn it off !, what can i do for this problem?
that tune is locked.omar0yah wrote:hi mikel, i bought a custom tune from a local tuner, and i asked him to turn of the Traction Control in the tune, and he said that he can't turn it off! and the device (intune DCX) also can not turn it off !, what can i do for this problem?
if he needs help, tell him to ask, but it can indeed be disabled in the tune permanently.
