I've heard the Diablo 93 tune runs lean under normal driving, and rich at WOT. After the longtube header install, I was thinking about increasing fuel across the board by 5% to keep it from running too lean with the headers until I can get my custom tune. Will this cause it to run too rich at WOT?
Installing them tomorrow. Can't do custom tune yet because my laptop took a shit..
Dodge Challenger longtubes w/Diablo tune
Re: Dodge Challenger longtubes w/Diablo tune
all vehicles run 14.7:1 at part throttle, regardless of tune, at WOT we run them leaner than the OEMs.
Do I need to do anything to WOT spark at the moment, or just WOT fuel?
just add a little fuel for now.
Does the 91 tune run as lean as the 93 tune?
they are the same tune except for the amount of timing commanded at WOT.provoc8r wrote:Does the 91 tune run as lean as the 93 tune?
Is there a way to clear engine codes with the Intune? Since removing my cats I'm throwing a code, and can't use my remote start.
you need a custom tune to disable the codes permanently.
madmike1210
Would I need to do anything different to my 07 rt after shortys because since I installed them it's been surging , I don't think it's getting enough fuel running the 91 cai tune atm
