custom tune not loading
6.0swhatuneed
Post by 6.0swhatuneed »
Hi guys, I just recently pulled the tune off my gmc sierra to update my intune. I reinstalled the fan and 4.10 gear tune on my truck and it seems like it's not working. My speedometer seems a good bit off now and the abs lights are on after driving for a couple minutes. The lights are off with every restart and come on after driving. Fans don't want to turn on either. I checked my wiring very thoroughly, I guess my pcm could be the problem, let me know what you think.
Shootin for the moon
Re: custom tune not loading
was it a custom tune, or you are just modifying the canned tune?
FWIW, you do not need to restore to update with intune ;)
6.0swhatuneed
Its a tune for 4.10 gears and electric fans on my sierra. I was having problems with fans prior to this so I figured I would update and start fresh with the tune.
so it is a custom tune, made by a cmr tuner?
mikel wrote:so it is a custom tune, made by a cmr tuner?
yes, Zach did it for him...
the custom tune file zach posted for him is here: http://diablosport.com/forum/viewtopic. ... 57#p275157
6.0swhatuneed
Has anyone had a look yet?
Zach
Post by Zach »
Can you post a last tune written and let me look over it?
What happens when you try to install one of the can tunes?
6.0swhatuneed
I'll post it when I get home here. Canned tune loads fine.
6.0swhatuneed
Here's my last tune written
PCM_12577909_LastTuneWritten.grg
(29.03 KiB) Downloaded 141 times
6.0swhatuneed
(29.03 KiB) Downloaded 157 times
6.0swhatuneed
I hope I'm not coming across as annoying, but have you figured anything out yet?
it's the weekend.. they're all gone until Monday bud...
Zach
Post by Zach »
Ok, somethings not right with the files i have. Please post everything from the Tunes folder on your Intune drive.
6.0swhatuneed
here's all of them, it won't let me attach the 4.10 gear and fan tune
(29.03 KiB) Downloaded 118 times
PCM_12577909_Backup.grg
(29.28 KiB) Downloaded 131 times
Zach
Post by Zach »
The Last Tune Written file you posted, which I assume is the file in the truck is for the 4.10 gear and has all of the fan settings correct for electric fans. Just in case I have remade that tune off of your backup that you posted.
pcm_12577909_410_fans_2.grg
(26.7 KiB) Downloaded 135 times
