custom tune not loading
6.0swhatuneed
Hi guys, I just recently pulled the tune off my gmc sierra to update my intune. I reinstalled the fan and 4.10 gear tune on my truck and it seems like it's not working. My speedometer seems a good bit off now and the abs lights are on after driving for a couple minutes. The lights are off with every restart and come on after driving. Fans don't want to turn on either. I checked my wiring very thoroughly, I guess my pcm could be the problem, let me know what you think.
Shootin for the moon
Re: custom tune not loading
was it a custom tune, or you are just modifying the canned tune?
FWIW, you do not need to restore to update with intune
6.0swhatuneed
Its a tune for 4.10 gears and electric fans on my sierra. I was having problems with fans prior to this so I figured I would update and start fresh with the tune.
so it is a custom tune, made by a cmr tuner?
yes, Zach did it for him...mikel wrote:so it is a custom tune, made by a cmr tuner?
the custom tune file zach posted for him is here: http://diablosport.com/forum/viewtopic. ... 57#p275157
6.0swhatuneed
Can you post a last tune written and let me look over it?
What happens when you try to install one of the can tunes?
6.0swhatuneed
I'll post it when I get home here. Canned tune loads fine.
6.0swhatuneed
Here's my last tune written
- PCM_12577909_LastTuneWritten.grg
- (29.03 KiB) Downloaded 141 times
6.0swhatuneed
- (29.03 KiB) Downloaded 157 times
6.0swhatuneed
I hope I'm not coming across as annoying, but have you figured anything out yet?
it's the weekend.. they're all gone until Monday bud...
Ok, somethings not right with the files i have. Please post everything from the Tunes folder on your Intune drive.
6.0swhatuneed
here's all of them, it won't let me attach the 4.10 gear and fan tune
- (29.03 KiB) Downloaded 118 times
- PCM_12577909_Backup.grg
- (29.28 KiB) Downloaded 131 times
The Last Tune Written file you posted, which I assume is the file in the truck is for the 4.10 gear and has all of the fan settings correct for electric fans. Just in case I have remade that tune off of your backup that you posted.
- pcm_12577909_410_fans_2.grg
- (26.7 KiB) Downloaded 135 times
