Running rich
ntymd8r
Running rich
Post by ntymd8r »
I have an 01 Camaro Z28 with a custom tune from 2005ish. She is now throwing a P0172 code. I have not done any adjustments to the tune since I had it made for me. Where do I start and what to do????
Thanks, Alex
Red 2001 Chevrolet Camaro Z28, SLP intake, SLP Y-pipe, SLP Loud Mouth exhaust, Predator custom tune U7198, BMR suspension components (STB, RB, Adj. PB, Adj. TA, RCA, Eibach Pro-kit
Re: Running rich
if the tune hasnt changed and the code came out of the blue, something on the car has changed, check O2s, exhaust, etc.
ntymd8r
Re: Running rich
Post by ntymd8r »
The P0172 code did just start. I have also had a P0430 code for the past year or so. So, possibly an O2 sensor that needs to be checked? She does smell very potent in the exaust though....
Re: Running rich
whatever it is, its a passenger side issue ;)
Likely O2, yes.
ntymd8r
Re: Running rich
Post by ntymd8r »
Thanks for your input and quick response, Mike!
ntymd8r
Re: Running rich
Post by ntymd8r »
**UPDATE**
She began throwing additional codes pertaining to O2 sensors. I started tinkering and cleaning. Since it was running rich, I believed the problem was in the intake. I went to the MAF sensor in the intake tube and found it was covered in goop and grime. Cleaned the sensors off and the codes never came back. My smog check passed with flying colors!
garrett
Site Admin
Re: Running rich
Post by garrett »
awesome!
