coolent fan
Re: coolent fan
One other thing. My daytime radio illumination, speedometer, and tachometer all are on max setting. Doesn't do this with stock tune.
Re: coolent fan
I have never heard of this before, could it just be resetting the settings after the flash?395hpwrs wrote:One other thing. My daytime radio illumination, speedometer, and tachometer all are on max setting. Doesn't do this with stock tune.
Re: coolent fan
Mike, i posted my last written tune. Any word on the fans? I can live with the other.You never responded today about that?
Re: coolent fan
You can update and use the settings in the new version to correct it
Re: coolent fan
Ok, plugged the tuner to laptop, says up to date. Can i control the fan in settings now?
Re: coolent fan
what are the stock settings for the fan? What does the 91 tune set it at?
Re: coolent fan
having same problem using mileage tune on 2011 ram 1500. Fans continue running all the time. Any solutions?
Firstgenfan
Re: coolent fan
Same issue here. 2012 Charger R/T, fully updated I-1000-DCX, 91 Octane tune, fan runs like it's set for a 180 T-Stat. Went in, verified all fan temps are at stock settings, and it's still doing it.
Re: coolent fan
post the tune file here please.
Firstgenfan
Re: coolent fan
Here it is.
Re: coolent fan
stock fan settings attached.Firstgenfan wrote:So, anything?
Re: coolent fan
I have a 2014 ram 5.7 8 speed trans. I also noticed the fans running. I updated my I 1000 today 3-10-2015. has there been a fix or do I need to adjust the fans with the tuner. I have not reinstalled the tune yet, waiting on a response.
thanks jim
thanks jim
Re: coolent fan
back to stock here.
