custom tune not loading
6.0swhatuneed
Re: custom tune not loading
Post by 6.0swhatuneed »
Thanks a lot, I'll see what it does tonight. Hopefully this just a totally random problem.
Shootin for the moon
6.0swhatuneed
Well, I believe the gear ratio is right, I don't have any lights on now. My fans still won't kick on. If I manually ground the harness they work. Any ideas? I do appreciate your help Zach.
Zach
Post by Zach »
Unfortunately, looks like an issue on your end. If i recall correctly, the fans were working perfectly, and then one day they stopped. That tune has all of the changes for the fan set properly and they are the same settings that you were using originally when the fans were working properly.
6.0swhatuneed
Hello again. I finally figured out my problem and my pcm was bad. I purchased a new one and installed it, truck runs with no codes. I can't get the custom tune to come up on the intune now. Will the old tune work with the new pcm? It is programmed for my truck and vin. Again, I really appreciate all the help.
you'll need to redo the custom tune from the new backup file.
6.0swhatuneed
Okay, here's my tunes again, hopefully for the last time.
PCM_12591789_LastTuneWritten.grg
(29.4 KiB) Downloaded 107 times
PCM_12591789_Backup.grg
(29.34 KiB) Downloaded 113 times
6.0swhatuneed
Anyone had a look yet?
Zach
Post by Zach »
Tune attached
PCM_12591789_efans.grg
(26.84 KiB) Downloaded 117 times
