n2mb wot box not working with diablo intune for caliber?
miztercorny02
hello,
i have an 2008 caliber srt4, i just recently purchased a n2mb wot box, and with some research, found that apparently, it does not work with the diablo tune unless given a custom tune. i contacted customer service and he said to ask here. he also said if needed, the custom tune is free. could you help me please?
thank you
thank you
Re: n2mb wot box not working with diablo intune for caliber?
Just post the tunes from the tune folder here. I'll make the necessary adjustments
Insert Clever comment here...
miztercorny02
sorry, where would i find the folder?
on the drive called intune.
miztercorny02
here you go sirs. I believe that should be it. any more info, please just let me know. thank you.
- PCM_05187661AF_LastTuneWritten.drg
- (636.02 KiB) Downloaded 619 times
Need the backup as well please.
miztercorny02
here you go.
so question, what does the custom tune fix? will it actually let my n2mb work? sorry, i just people talking about this online.
- (636.02 KiB) Downloaded 727 times
- PCM_05187661AF_Backup.drg
- (636.24 KiB) Downloaded 517 times
Here you go.
- pcm_05187661af_2step.drg
- (577.36 KiB) Downloaded 460 times
miztercorny02
thank you, hopefully it works.
this is equivalent to the diablo tune right? using 93 octane?
JECU_CSRT4
HI I TOO HAVE THE SAME PROBLEM WITH THE WOT BOX COMES IN LIMP MODE, THAT TUNE SOHFAST94 ALSO CAN I USE IN MY CALIBER SRT4 OR IS ONLY FOR MIZTERCORNY02?
THANKS
THANKS
Only for him. You want it you'll have to post your tunes as well.
JECU_CSRT4
HERE IS THE ORIGINAL BACKUP OF MI CSRT4, WITH THIS UPGRADE FOR WOT BOX CAN I USE TOO THE 91OCT TUNE AS WELL LIKE BEFORE?
- PCM_05030396AJ original backup.drg
- ORIGINAL BACKUP
- (781.05 KiB) Downloaded 699 times
JECU_CSRT4
I FORGOT THESE
- PCM_05030396AJ_Perf_93oct.drg
- (3.25 KiB) Downloaded 353 times
- PCM_05030396AJ_Perf_91oct.drg
- (3.25 KiB) Downloaded 458 times
Which one are you running currently?
JECU_CSRT4
