ABS Light
mmitchell
ABS Light
Post by mmitchell »
I have a 2013 Jeep Grand Cherokee 5.7 Hemi. I adjusted the tire size to match my 275/65/18s and am now experiencing a stuck ABS light. I tried to reset to the stock tune but that did not fix the issue. I have the current 1r13 version applied to the trinity t1000. I was wondering if there were any other steps I could take to correct the issue or if there is a fix available online.
I also had a question about 87. Will I run into issues if I use 89 octane will running that 87 tune. I did not see any options for 89 on the device.
Thank you for your time.
Re: ABS Light
restoring the stock tune, then updating to 1r13d then reapplying the tire size should fix it.
98 will work fine with the 87 tune.
mmitchell
Re: ABS Light
Post by mmitchell »
Thank you for the quick response. However, I cannot find the version 1r13d anywhere on this site. Do you have a link for that download?. Thank you.
Re: ABS Light
restore the stock tune then connect to a pc, open dsdl, and it will auto update assuming the tool is registered.
BlackOverlandHemi
Re: ABS Light
Post by BlackOverlandHemi »
Does this actually work?
mmitchell
Re: ABS Light
Post by mmitchell »
I plugged the device in and ran the downloader program. I didn't receive any new updates. I figured the site would host the last revisions of the .crom files but I was unable to find the update "1r13d". Is there a direct link to this download?
Re: ABS Light
its 1r13c actually, if the device is registered it will auto update, did you restore the stock tune first?
mmitchell
Re: ABS Light
Post by mmitchell »
I actually ran the update on the device prior to trying to change the tire size. I tried to reset to stock but the light still stayed on. I haven't flashed a full tune on the vehicle yet. I was planning on flashing the 87 tune. Will that fix the abs light issue, if I also set the tire size to what I'm running?
jrod922
Re: ABS Light
Post by jrod922 »
Has a resolution been given for this ABS issue. I also input the tire size and got the light. Plenty of threads on the problem, but still yet see how to fix this?
Mongoose9400
Re: ABS Light
Post by Mongoose9400 »
Help. ABS light stuck on. 2012 Jeep SRT8 after trying to adjust tire size. With the ABS light on is ABS disabled?
Re: ABS Light
Mongoose9400 wrote:Help. ABS light stuck on. 2012 Jeep SRT8 after trying to adjust tire size. With the ABS light on is ABS disabled?
is the device up to date currently?
Mongoose9400
Re: ABS Light
Yes. Tool is up to date. Tool automatically updated yesterday. dcx 1r13c
Mongoose9400
Re: ABS Light
Just took the car to a dealer and got it fixed for $100. Just needed to reflash the correct (stock) size back.
