Extreme power puck throwing p0102
mxtime
Post by mxtime »
2008 lmm duramax
Fully installed and shimmed also.
Throws P0102 code when I get on it hard and have the knob turned up more than ~30%.
Fuel pressure drops to 10000k.
Also boost on my electronic boost guage goes down to 20psi from 25psi on max effort when I hve the knob turned all the way up..
Is this because of the boost fooler?
Re: Extreme power puck throwing p0102
the fuel pressure sounds like the shim is not allowing it to hold pressure.
the boost is a result of the boost fooling, yes.
mxtime
Post by mxtime »
Thanks for the reply Mike.
I put three shims in so I don't think it's that. I think it may be dropping the rail pressure after the MAF code/error maybe?
mxtime
Post by mxtime »
Does the puck "fool" the rail pressure in the same sense as it fools the boost? Meaning does it show lower rail pressure on an electronic guage when the knob is cranked?
mxtime
Post by mxtime »
Follow up.
It was my fuel filter causing the drop in rail pressure. Had it replaced and all is good there.
Still have code P0102 though
