Latest Intune release here.
For inTune users who prefer to not use Windows, we'll help you out in your own section.
ram2014
need help , 2014 ram 5.7 8 speed, traction control fail
Post by ram2014 »
2014 ram 1500 5.7 hemi running base tune, tire size changed to 36x14, cant disable traction control getting error saying traction control fail to update what can I do to fix this? :evil:
rbrose999
Re: Latest Intune release here.
Post by rbrose999 »
I am having troubles, my tuner says it is up to date, when plugged into car it says may need a pcm calibration..
info.xml
(1.78 KiB) Downloaded 454 times
- <tool_info>
<main full_version="InTune-1r04d 08/15/2014 12:04:06 PM" sw_rev="1r04d" svn="7842" />
<registration sn="KUD268D-8" status="1" />
<cal_id PCM="05035304AF" />
<restore id="0" vin="2C3CDYCJ1CH180842" bc="39" />
<system_db info="1r01b" dtc="1r01a" vin="1r01e" />
<db mfr="DCX" tune="1r01s" pid="1r01b" />
<db mfr="FORD" pid="1r01b" />
<db mfr="GM" pid="1r01a" />
- <license avail="1" tuned="1">
<tuned vin="2C3CDYCJ1CH180842" />
</license>
<updates count="11" />
<oem tool_oem="DIABLODCX" />
<reg reg="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" />
</tool_info>
info.xml
(1.78 KiB) Downloaded 425 times
your VEHICLE needs an update, not the tool...
do what it says on the tool.. have to go to diablo's site, download the pcm update for your vehicle and load it in the tool.. then connect to your vehicle and install the vehicle's PCM update...
then you'd be able to tune it..
rbrose999
Post by rbrose999 »
06MonteSS wrote:your VEHICLE needs an update, not the tool...
I have done search after search, no luck finding where to get pcm update on diablosport.com site. Under downloads it brings me to page 1 of this forum. When I try to force calibration update in car, it says intune is holding an original backup. I had the 91 oct. Tune on it last Month when I got an oil change at dealer, it was flashed and has been a brick ever since.
Any advice is greatly appreciated
so you did not restore the original backup stock tune to the vehicle first before going to the dealer, and the dealer flashed your pcm?
and here are the instructions for the dodge/chrysler Vehicle updating:
http://www.diablosport.com/spages/suppo ... rinity.pdf
rbrose999
Post by rbrose999 »
As for your Q, no, i forgot to remove the tune before i took it in. i have an Intune DCX tuner though, the trinity instructions seem like they are a little different, but i appreciate the response. i've even tried removing the vehicle from the tuner or reset the registry but somehow i can even enter the correct code as i run out of number space on the screen..
aaah.. so you may need to have diablo techs unlock/reset the tool first then before it will work, since they reflashed your ecm and you did not restore the backup first... so the tool is still locked to the previous calibration from before they updated it...
1-561-908-0040, option 1 for tech support... Mon-Fri, 9am-6pm (EST).
raulsanchezaldana
Post by raulsanchezaldana »
hi im new on this just got my intune yesterday i wanna use it in my 2001 v6 3.8 mustang, Any recommendation ir tip would be great thank you
justin08
Post by justin08 »
have an 04 hemi ram and when I plug the tuner in it says I need to update to read the vin which download do I need
justin08 wrote:have an 04 hemi ram and when I plug the tuner in it says I need to update to read the vin which download do I need
replied to your other post already...
bamaboy87420
Post by bamaboy87420 »
I have 2012 Dodge Ram 1500 express with the 5.7 Hemi... just bought the Diablo inTune i1000 and also a K&N CAI and Airraid throttle body spacer. i wanted to use the 91 octane tune but i could only find 92 octane at WAWA will it work together............i filled the tank up all the way so im kinda stuck with the gas......... any suggestions for the best tune for my recent up grades and the gas i have in it. THANK YOU FOR YOUR TIME :shock:
CarlinD
Re: Mac version to download
Post by CarlinD »
mikel wrote:latest tune databases:
DIABLODCX update is for 2011-2014 Dodge/Chrysler/Jeep vehicles
DCX update is for 2003-2010 Dodge/Chrysler/Jeep vehicles
Hey guys why isnt there a mac version for the drivers?? :crashing: :crashing: :blowup:
Jeep Grand Cherokee Limited 5.7 HEMI Australian Model
bamaboy87420
Throttle Body Spacers
Are Throttle Body spacers bad for the the inTune i1000? :shock:
don't waste your money.. they don't do anything for ya.. gains you nothing...
those are an old-school carburetor trick and does nothing for newer fuel injected vehicles... it can also mess up the air flow and make things worse...
leebaskin
Post by leebaskin »
am I missing something or was the last update done in 2012?
I login and try to do an update. but I keep coming back to this post... did I miss something?
Return to “Mac/Non Windows based issues”
