2014 3.6L SE Tune Question
Markerbe1
Post by Markerbe1 »
Hey guys, just got my T1000 I did an 89 octane tune with it. How do I remove the governor and change the shift points? Or is that only available on the higher octane tunes? Thanks!
Car:
2014 3.6L Dodge Charger
Mopar Stormtrooper -- San Antonio, TX -- '14 DODGE Charger 3.6L: K&N, Flowmaster 40 Series, fiberglass SRT style hood, push bar, FCKlightbars 20" S1 Series lightbar.
Re: 2014 3.6L SE Tune Question
after you select the tune choose the option to modify the tune and go to rev/speed limits and raise the speed limiter, then hit the back button until it asks if you want to install the tune and choose yes.
Shift points are not adjustable on the 3.6, it already shifts pretty high :)
Markerbe1
Post by Markerbe1 »
mikel wrote:after you select the tune choose the option to modify the tune and go to rev/speed limits and raise the speed limiter, then hit the back button until it asks if you want to install the tune and choose yes.
This can all be done on the device, right?
yes.
