Is , power enrichment & injector slope----- adjusting AFR
ol green ford
Post by ol green ford »
well I got an 01 Camaro ss. It has longtube headers & k&n air filter. I do have the Intune - 1000 and I did update it. I just orders my AFR gage and hopefully I'll have it installed next week. Soooo , I'll be running the canned DS tune and will be fine tuning it with my AFR gage. My thinking is ill check it at idle & at cruise 2k rpm @ 70 mph "ish". I'll will check WOT by. Cruising at 2500k RPMs in 4th gear and then just stab it to redline. To check the AFR. So is this a good way to tune "get it close" with an AFR gage. And is the. Injector slope & Power enrichment. The only fuel adjustments I can make with this Intune. ? Thanks for you replies. Bret m
Re: Is , power enrichment & injector slope----- adjusting AF
You need a wideband, an AFR gauge wont work properly...
ol green ford
I bought the AEM wideband UEGO. Is this one going to work well?
OK, yes, I thought you meant an AFR gauge that ties into the stock narrow band O2 sensors.
ol green ford
Also !! Maybe some opinions on this would help. What side is the preferd side to "tune "off of on this LS1 motor.? Installing the 02senser.
ol green ford
How does these fuel trims look. This at idel after fully warmed up. Drove it about 5 miles. And 1% smaller on the injector slope. One of the LT fuel trims is -16. Weird....
Return to “Predator GM Gas”
