Help with K&N CAI and such!
Kendragon
Post by Kendragon »
Help with tune for 2014 Ram 1500 5.7, K&N cold air intake, throttle body spacer, Trinity1000, and magnaflow exhaust. Is there an option to select cold air intake installed? Intake will be in tomorrow. Any help would be appreciated. I already tuned for 93 Octane.
Re: Help with K&N CAI and such!
No CAI option for the Ram. No increase in flow, no leaning out, no need for a CAI tune.
Kendragon
Post by Kendragon »
BUt it will still make the vehicle run better right?
Kendragon
Post by Kendragon »
Mike_Levy wrote:No CAI option for the Ram. No increase in flow, no leaning out, no need for a CAI tune.
I saw on another post it would hurt to add 5% to wot. Is that true?
no, that wont hurt anything.
Kendragon
Post by Kendragon »
mikel wrote:no, that wont hurt anything.
I don't show the wide open throttle in percentage. It give me the choices of 1k-3.8k , 4k-4.8k, 5k-7k. Which is the equivalent to 5%?
those are the rpm ranges in which you can increase the WOT fueling.. so select an rpm range you want to change, then you will get to the percentage adjustment.
Kendragon
Post by Kendragon »
06MonteSS wrote:those are the rpm ranges in which you can increase the WOT fueling.. so select an rpm range you want to change, then you will get to the percentage adjustment.
Any help with my throttle, WOT, repsonse etc with my CAI thottle body spacer and single magnaflow exhaust
