P0605 on '13 GT500
mrl859
P0605 on '13 GT500
Post by mrl859 »
I used my trinity to adjust for the different tire size and rear end gears and I keep setting a P0605. Ideas?
Re: P0605 on '13 GT500
can you load the tune then post the files here so we can take a look please?
mrl859
Post by mrl859 »
mikel wrote:can you load the tune then post the files here so we can take a look please?
Actually, I loaded your canned 91 Octane tune modified for my tires/gears and also is well. Lots of low rpm/light throttle pep off the line too. Nice. Thanks.
right, what I need to have you to please is load the tunes to the car with the changes then export the files and post then here.
mrl859
Post by mrl859 »
Export the files that are in it now, which are not creating a check engine light?
Oh, no, if its ok now, no.
What tune were you using when it threw the code?
modify stock?
mrl859
Post by mrl859 »
mikel wrote:Oh, no, if its ok now, no.
modify stock?
Exactly. I did not try to reload modify stock. I just loaded modified 91 octane. All is well with the world. As an aside, ALL the guys on ALL the GT500 forums always say go SCT. This being the fifth car I've tuned with my Trinity (Cadillac included), and based on the way I rotate cars, I'll stick with my Trinty.
Glad to hear it :)
mrl859
Post by mrl859 »
mikel wrote:Glad to hear it :)
Mike, how do I pm you without AIM?.
screenname is mikediablosport
mrl859
Post by mrl859 »
Back again. I am using the Trinity to use a modified stock tune to allow for axle ratio (3.73) and tires (717). Each time I start it, I get a check engine light with a the P0605 code. I clear it with the engine running and I'm good until the next time I start it. Ideas?
sohfast94
Post by sohfast94 »
Load it and read out the last tune written I'll change it for now.
Insert Clever comment here...
mrl859
Post by mrl859 »
How do I do that?
mrl859
Post by mrl859 »
Okay, here is the stock and last tune written. Can the correction(s) be made in such a way that if I change tire revs/mile later, I won't have the same problem? BTW, the light comes on with p0605 about ten seconds after start up.
PCM_FGFC3B5_Modify_Stock_Tune_modified.frg
Modified stock
(1.25 KiB) Downloaded 314 times
PCM_FGFC3B5.frg
Stock file
(697.59 KiB) Downloaded 337 times
sohfast94
Post by sohfast94 »
Plug tool into pc and tell dsdownloader to get tune from tool. Download both selections original backup and last tune written. Then post the last tune written.
http://diablosport.com/downloads-updates?pid=2
If you need DSDL it's at the bottom of the posted link.
Return to “Trinity Ford Gas”
