TIRE SIZE UPDATE ISSUE (2014 Grand Cherokee 3.6L)
I have an issue updating the tire size on 2014 Grand Cherokee 3.6L it gets to 10% and the ABS light flashes and says failed to apply. My speedo is then off 4-5 km/h
please advise on a fix or patch...
Other then this all his good on updates and applying the tunes
Thank you
SIDIAMIR
K&N 77-1560KTK
Thank you
SIDIAMIR
K&N 77-1560KTK
Re: TIRE SIZE UPDATE ISSUE (2014 Grand Cherokee 3.6L)
please post the info.xml file from the intune drive.
I have an issue updating the tire size on 2014 Grand Cherokee 3.6L it gets to 10% and the ABS light flashes and says failed to apply. My speedo is then off 4-5 km/hmikel wrote:please post the info.xml file from the intune drive.
Thank you
SIDIAMIR
K&N 77-1560KTK
we will look into this.
mikel wrote:we will look into this.
How long mikel for a fix....
UP... so you don't forget me...
good day any news on this issue as 4-5 km hrs more makes the odometer tic faster as well...SIDIAMIR wrote:UP... so you don't forget me...
Hate to tell you but if you go to page 3 you will see another thread with same issue that they haven't bothered to fix that was asked in September of 2014. They don't care. They say they will look into it but looks like they don't. It's sad to see paying customers getting the shaft. I am in same boat waiting for the correction.
As soon as we can get a newer 3.6 Cherokee or Durango in here i'll have this sorted out.
I've heard the tire parameter is in the bcm not the ecu. Wonder if that's the problem why it won't work.
2 months later and STILL nothing.
Yeah I have the same issue with my charger, where tire parameters, and axel ratio fail, same with tcm adaptation. Been like this for almost two years with no fix.
ANY NEWS ON THIS ISSUE....
