3.73 Gears with custom tune
Virge
Post by Virge »
Hi, i've just installed on my mustang a 3.73 gears..
I have a custom tune, if I change the axle ratio with the predator it will be adjust the speedometer only or also adjust the shift points?
Re: 3.73 Gears with custom tune
it will bring it all in line :)
Virge
Post by Virge »
Thanks!
I set "3.73" in the axle ratio and set 746 on tire revs for mile (i have a 255/35 20), but i noticed that the speedometer is about 6/7 MPH faster than the GPS signal... Why?
did you select the enable axle ratio change parameter as well?
Virge
Post by Virge »
Yes, i set the axle ratio and tire revs for mile and i install the tune, but speedometer is wrong.... if I send to you my tune can you correct it for the new gears? Thanks!
Virge
Post by Virge »
I tried to install a 95 mm tune (i have a ford racing cai), and i set the 3.73 axle ratio but my speedometer continues to be wrong. I try to install my original backup and I set the 3.73 axle ratio but the problem has not been resolved...
What can i do?
export the files and post them here please.
Virge
Post by Virge »
Thanks, I attached the file
91R-R2.2-FRPP.frg
(960.17 KiB) Downloaded 356 times
sohfast94
Post by sohfast94 »
Here you go. All fixed. There were some old errors here that will be fixed this week and out on the next update.
91r-r2.2-frpp_373.frg
(960.17 KiB) Downloaded 325 times
Insert Clever comment here...
Return to “Predator Ford Gas”
