2006 Pontiac Grand Prix GXP diablo tune issues
I just purchased an diablo trinity for my 2006 Pontiac grand prix gxp, and when I install any of the tunes I get an looping idle, currently using just the modified stock tune. Only mods to the car are an CAI air intake and a SLP 160 thermostat, NGK laser plugs and bosch wires. Need help please
Re: 2006 Pontiac Grand Prix GXP diablo tune issues
yep, I know exactly what the problem is..
Did you update the trinity first to the lastest updates before installing the tune??? I thought that issue was fixed a long while back...
the issue can be fixed in a custom tune.. post up your ecm original backup and last tune written files...
Ok I will as soon as I get home from work. Which is like 7pm est time
Here is my original backup and last written tune
- TCM_235742236494_Trans_Firm_Shift_Tune_modified.grg
- (2.25 KiB) Downloaded 508 times
- PCM_602095602425_Modify_Stock_Tune_modified.grg
- (3.25 KiB) Downloaded 327 times
- TCM_235742236494.grg
- (13.63 KiB) Downloaded 354 times
- PCM_602095602425.grg
- (42.92 KiB) Downloaded 291 times
so you're only running the stock tune? you should not have the jumping idle if you are only running the stock tune.. that issue only happens with the diablosport tunes...
so which tune do you want the fix for???
you'd need to select/install the tune you want to use - 91 octane No DOD or Diablo Tune No DOD...
then you need to post up the last tune written file after that, so the fix can be applied to an actual tune...
Yeah, its just when I installed the diablo tunes, I will install one then upload it
Here are my last written diablo tune
- (2.25 KiB) Downloaded 327 times
- PCM_602095602425_Diablo_Tune_no_DoD_modified.grg
- (5.25 KiB) Downloaded 349 times
hmm.. can't even open your tune files.. no tune template for your calibration...
Mike/Zach, any ideas? need a new template for this???
If i do an data log from stock could you make me an tune, and if i drive the car with that looping idle will it harm the car
Someone had told me that I probably have to relearn the throttle body, is that true?
can't make anything for you at this point, there's no template for your particular calibration.. so can't open your tune files... engineering has to create one, and from what I hear, it won't be any time soon... that's an ollld calibration, so it's not at the top of the list of things to do...
What if i go to the dealer and get my computer updated?
yes most likely..
make sure you restore the original backup stock tune to the car first before going for dealer flash update..
I finally took it to the dealer for an update, but it still surges when accelerating, can you fix it for me please og
- (2.25 KiB) Downloaded 382 times
- PCM_604792604820_Diablo_Tune_modified.grg
- Diablo Tune
- (4.25 KiB) Downloaded 311 times
- Tcm
- (13.63 KiB) Downloaded 246 times
- PCM_604792604820.grg
- updated original pcm
- (42.91 KiB) Downloaded 299 times
06MonteSS would you be able to help now?
